  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Nizmo
guys get jealous of the attention i lavish on my car - its quite petty very funny tho. Your a weird species!
Other skyline owners get angry with the amount of care I don't take with my skylines appearence, several have mentioned the idea of confiscating it from me. And others have talked of transplanting the features of the southern rock cod onto the body of a common vole using gene manipulation... this is very disturbing.
My R33,I think of it as my fast little 'rubbish receptical', don't litter Australia on the other hand.
Wonder if I can fit a boat toilet in the middle of the back seat, puts new meaning to the words 'dump pipe' on a skyline.
