Originally posted by Sneeza
Ken - he knows what I am doing - plus is his bucks night tommorrow night so I'll be glad not to listen to his hung over whinging on sunday hahahah
He might know what your doing but does he know what pwpt60secf is doing ?
Come to think of it , does pwpt60secf himself even know what he is doing ?
Hehehe
Cheers
Ken
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Ken,
That's not very nice, besides not much room to dance on my head:p
See'ya:burnout:
True but Sneeza could show him a few Irish jig moves that will fit.:P
Cheers
Ken
Ken,
Stop trying to worry Liz, or me for that matter, I don't know what I might do now.:P
See'ya:burnout:
yea sorry , all jokes aside .
Sneeza , you will be fine and will have a great time with Paul.
If you don't , just tell us here and WE will dance on his head.:D
Cheers
Ken
car is ok. I don't really like the new front end - but beggers cant be choosers. The car doesn't feel right - maybe that's cause I haven't driven it for so long. But i can't hear the air sucking in like I used to - or the turbo spooling... and I loved that noise!
I raced someone tonight in a subaru.... and I won!! I was sooo happy hahahaha. I didn't start the race - I tool off normal from the lights and he started caning it so I floored it and beat him YIPPEEEEE
Yeah, I'm with Liz, stop trying to get me in the shit. *sob*
See'ya:burnout:
pwpt60secf , you are always in the sh*t.
It's only the depth that varies.:P
Cheers
Ken
I just hope it doesn't rain, but the weather is starting to look good:p
Ken, Will you been part of any rally support crew, or just there representing Maximum?
See'ya:burnout:
Huh ??
As I said , we are running 5 cars in the event with a service crew of 15 -18 people plus hangers on ( wifes , Daughters , b/f's , g/f 's kids ) etc making about 35 in total and my job is team manager.
So , yea , spose I am part of the support crew.
Cheers
Ken
Ken - why what happenned last nite? Sorry I don't usually read back......
Paul - *big hug* I'll save you from nasty old ken hahaha
Don't waste bandwidth , about lunchtime it is the
* days of our lifes * with pwpt60secf and Niz usually and at night we bag pwpt60secf before he comes on about 11pm.
It's all good:)
Cheers
Ken
Err , who PM 'ed Paul to get you after you told me what suburb you were in ?
Cheers
Ken:D
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
    • Given it happened suddenly, and when you come on boost, I'd check all your inlet - hose clamps in place and no split rubber or silicone hoses. Even the hard to get to ones near the intercooler. It's possible air that went past the air flow meter is being dumped out a big hole.
