had some great fun on the freeway tonight... a f&f (fast n furious) stickered silvia was trying to chop me.. but got chopped.. then when we pulled up at the lights - they said "GTR right?" and I said "Nope - just a lil old GTST"...
Lots of disappointed and suprised looks from the silvia occupants... hehehe
:chop:
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Nizmo
mmm apparently i have viking in me - looong way back tho - might explain the fiesty nature - i guess viking and ned kelly arent exactly the best mix :( oh well can choose your friends cant choose your family.
im 6'1. ;) Not that hard to get a guy taller than me - seem to not have much of a problem - i seem to attract a lot of footballers!!!!
If you have eyebrows that are thin (ie: you can see through them --- opposite of greek eyebrow thickness) then you have strong viking blood.
do you know how many times a day i get asked if i play basketball? I would be a multi-billionaire if i had a dollar for everytime i got asked that! Most pathetic i sthe people that stroll up to you and think they are the first ones to ever ask you that and that they are funny. I shouldnt be harsh but the amount of times i get asked that it pisses me off - i dont even like the sport!!
uummm sorry Niz I forgot to ask you 1st time we met!
Do you play basketball? :shake:
cheers
Joe
didnt say only guys that are taller - been both sides of the fence - i like bear hugs ;) its hard to get those with a shorty a guess. U aint that short cam haha besides dont you have a missus :(
*note to self nizmo and sport especially basketball don't mix*
hehe
Joe,
I wish it was a comb over.
NiZmo,
I would never ask the basketballer thing, instead I say "WOW are you an underwater income tax accountant? Do you really have gills? Do you really write balance sheets with special underwater carrots?" you know that kind of thing....
cheers
Joe
Joe thats a better nic than your car pic , but only just.
Ten Commandments, wtf?.
I have a couple
1 Don't speed
2 If you do don't get caught.
Cheers
Ken
no me and sport do not mix - unless its motorsport :( I dont mind spectating on the odd game of footy or soccor but thats it - dont even mention cricket blahhh! rather watch paint dry or grass grow!
add these to your note Troy!
*don't piss off Niz, she will ripp into you*
*dont menstion about plastic burning smell in the car*
*Dont ride wiht her when she is in bad mood*
You learn fast young grasshopper. I dont get pissed if you mention the smell coming from my car - it makes my car different, adds character - bit like pauls gay wing makes his car different.
no me and sport do not mix - unless its motorsport ;) I dont mind spectating on the odd game of footy or soccor but thats it - dont even mention cricket blahhh! rather watch paint dry or grass grow!
Well then jump in the car with Macka and pwpt60secf and come down to watch the Forest Rally.
I'm sure you will all bond well on the trip down.:(
Bwahaha
Cheers
Ken
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
