  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Ahh buggered if i know, its running on all four now which is good but low and behold after its maiden run i open the bonnet and there is oil all over the place. there is a leak somehwere near of behind the CAS cover and its spraying all over.
The coke bottle worked good though ;)
Hopefully ill take of teh CAS cover and there it will be some little o ring or something taht obviously need replacing. Either that or a big crack down the side of the block :eek: might need an engine upgrade :eek1:
Yeh that is where its coming from. Ya know the little oil breather box thingy? we we ripped that off and replaced it with a CPU heatsink (dont knock it it works) and from the little gap next to it u can see it all come out. Alot of smoke too
hmm well im not at home and i dont have adigcam so there are afew obstacles.
Ya know the valley with all the plugs and crap? well there is a little flat bit of metal on one side and a little box that sticks out of the rocker cover and joins the breather pipes from the intake to the ahhh other thingy. yeh that part
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
