yeah niz im with cam! about the jash thing!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
yeah and cam but if i get a dump pipe to suit right, don't ya think it would make another place for exhaust leakage? that why i was thinkin of sellingmy apexi front and just getting a new dump/front made up!
i agree coilovers are awesome! but i can't justify paying that much unless i was harcore track racer! so i think i just go for the aftermarket shocks and springs!
adrian:p
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
dont really have itme to chase thats why i now use who i do - seems to be very thorough and has the time on his hands to be that way.
I'll get it done just got to find time n money - but first the blow off valve problem - one step at a time - should see the shopping list i have for my car - i mean just even the essentials its huge - need my brake pads replaced soon too or i might end up under a truck!
niz i have a blow off valve that i wanna sell! it's a ssr blow off valve styled like blitz! bit fatter though! apparently very loud (look at me loud) hehe although never put it on my car! if ya want you can take it off me to see if it will fix your problem, if it does you can buy it if ya want, if it doesn't then chuck it back at me in a big tantrum! ;)
adrian :D
Adrian - ok, I get what ur on about now - and i agree.. u should be able to get rid of the Apexi pipe and use the proceeds to get the dump/front combo done?
Niz - understand completely.. thats one thing i hate, chasing people so they can take my $$... fair call..
sorry niz it ain't a re-circulative BOV, it's a atmo-venting BOV :D
but i'll have a talk to a few mates might be able to get you one at a good price i'll see what i can do! why is ur stock BOV playing up or sumfin?
adrian ;)
mines aftermarket - there when i got the car - doesnt make a noise its just leaking air at the moment so its playing havoc with my idling and keeping the revs low so once i get that fixed then i can get it tuned and hopefully it'll be back to its feisty old self - its being sluggish lately and its boring the hell outta me ;)
hmmm wouldnt mind a bit of a ricey loud one. yeah keep your ears out for me anyway - might start looking for one saturday morning because i just want my car back to normal ASAP.
adjust the spring tension on the bov you got at moment? have you tried that? that should stop it leakin! just don't adjust it too much that it's too tight for the pressure to release when your off the throttle! are you going to auto salon niz? cam? if you guys are i'll be there saturday, tell me in advanced adn i'll bring the bov along with me on sat incase your nearby i can drop it off!
adrian ;)
going on Sunday. Hmmm spring tension - me under bonnet equals disaster - would rather be able to blame someone else if anything goes wrong but i may have to have a look anyway if its easy enough. Where abouts are u adrian? arent u thornlie way?
i'm in east cannington i go to thornlie tafe! what type of bov is the one ur using? coz i'm sure if you adjust the spring tension make it just a bit tighter it will stop leaking! coz you haven't upped your boost pressures or anything have ya?
adrian ;)
ahh k.. so the aftermarket one is hanging off the std mount then I take it?
I'm with Adrian - pull it off, clean it and tighten up the spring pressure.. Maybe get your mechanic to do it? Shouldn't take him more than an hour..
i think the boost is up a little more than standard ;) honestly i thought everything was standard apart from the obviousl lowering etc in my car when i bought it - but ive learnt lately that all is not what it seems - it has been played with. So im still learning what exactly is under that bonnet - i assumed that BOV was std til i was recently told otherwise - its nothing ricey looks like fairly standard - havent really taken a close look for myself lately - havent had time might have a look see this weekend see if i can find out make etc
you can do it yourself niz if ya have the right tools!
you probably wouldn't even need to take it off just adjust the spring tension there is normally a lil knob on top of the valve near where the hose from inlet plenum goes if i do remember rightly!
adrian ;)
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
    • I'm interested,do you still have it?
