  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
http://www.skylinesaustralia.com/forums/at...=&postid=239200
http://www.skylinesaustralia.com/forums/at...=&postid=239205
http://www.skylinesaustralia.com/forums/at...=&postid=239210
there ya go paul!
and when i say dash, i mean like the surround you knwo the black thing that surrounds the stereo and aircon shit!
adrian :)
