  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
troy i have to go to the bp next to rocko city. i dont like goin there. they guy goes out and smokes next to the bowsers at about this time. i fear for my life. but ur emting me
Psiker.
shuto. i didnt get on to well with the way they teach in oz. i dont like they way they teach english. it should be taught like how u woulfd learn indonesian. then maybe kids would have a better grasp of it
I don't know about moving back to Malaysia.
- eveyone drives like nut jobs
- drink driving seems social accepted
- price of cars is crazy (~AUD$50k for a camry)
- road tax (if you're paying it) is an absolute killer!
- the weather would suck for our turbos :P
    • Tried to make 1/8npt threads into compressor house of the turbo for my EBC. Threads got fu#ked and ended up with and elongated hole, so I do have good amount and nice threads 90% of the hole but 10% I only had 1-2threads there and rest of it is flush on that side of the hole.. So my idea is to do M12 x 1.25 to AN4 with braided lines instead of 1/8npt to 4mm vacuum silicone hose.  and hopefully get a better thread. M12 is quite big and AN4 is a little bit bigger than 4mm (4.9mm inner diameter braided PTFE hose). but this should work. Thoughts? Otherwise I will weld and adapter onto the turbo.
    • Looks great, I hope everything is working well after all that time!
    • Finally back on the ground and once around the block for the first time in 2+ years
    • Ok a solution was found. I had left the factory oil temp sensor in and it was hooked up. My car never had the triple gauges.  Apparently when you delete the factory pressure and leave the temp sensor connected it triggers the oil light on the dashboard. Disconnected the temp sender, no more light.  I still haven't gotten around to look at the diagrams to figure out how/why they are tied together.
