  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by darK
cya joe..
ken, cant i go under my mums name? shes a rating 1
Don't know , check with your mums insurance company.
Anyone under 25 over here gets bent over by the companies.
Cheers
over 25
Ken
Cheers
over 25
Ken
will i have any chance of importing a late model chaser? not an old one.. but at least 93 and after
Originally posted by GTS-t VSPEC
Ken,
It is possible, 3 entries last year did it, but we'll see what we get given, then make decisions:D
Joe, Night mate, are you coming tommorow?
See'ya:burnout:
OK , so who has stuck there hand up.
I assume you and me and who else.
GTRNIK ?
Cheers
Ken
If someone is doing Compliance , yes you can import one.
Cheers
Ken
Ken,
We have lots of interest:D
Me, You, Killer-T, GT NIK, Caminperth, Zanda, Adrian, R33 Impul, NO RSPECT, Judged, plus  a few others.
So depending on how many spots we get we may or may not need to limit numbers.
See'ya:burnout:
Apart from mine , aren't they all 33's ?
Cheers
Ken
ken..
this was written after the specs of the Chaser Mk V (97 model)
Dark , modified ones are out atm.
If a compliance ( read RAWS w/shop ) applies and does all the paperwork for a 93 or so chaser then I would saay you will.
Trouble is that is going to cost around $20+K to do it.
You have to work out if there is enough profit to warrant doing it ( ie are they going to sell enough to get there money back ).
This is why 92-94 GTR's may be defunct cos atm , no one is bothering to comply them
Cheers
Ken
Ken,
Yes, that's why I'm trying to get people like EVL R33 and the black R34 GTR interested.
Although NIK's doesn't look like a GTS-t:D
See'ya:burnout:
NIKS doesn't even look like a GTR .
It is WAAAAY wilder than that:D :alien:
Cheers
Ken
hey.. u know how P Platers have a 125kw/per tonne limit..
mitsubishi fto
6A12 G MIVEC Engine – 168kw/tonne
6A12 G DOHC – 145kw/tonne
Not in Good Ole WA
Cheers
Ken
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia body...
    • This. A 3d wheel alignment is like $120...just take it to the shop. Since theres probably multiple adjustments that need to be made after changing something. Mine has front/rear lower arms, traction rods, tension rods, camber arms, toe arms, front upper arms, hicas kit, sway bars and coilovers. I measure from the edge of the bolt holes on the originals and set the same length on all the adjustable stuff to dial it as close as I could to OEM. Took it straight for alignment; it didnt feel right at all...after alignment, it feels perfect. Similarly i've just changed the springs on another car; and I still needed multiple adjustments to bring it back in spec.
    • A full Veilside kitted JZA80 Supra in Meriken park in Kobe city a few weeks back
