Originally posted by Nizmo
haha havent u had enough of me for one weekend paul? :D U saw it today its filthy if i dont do it then it'll be ugly and weird smelling (although i have either got used to it or its disappeared) for another week.
Quick question: My steering wheel vibrates at 80km and by 120km its shaking hella bad - its had a wheel alignment done but its still like this and its really annoying! Anyone know whats causing it?
Wheel Balance or your nuts are loose.
Cheers
Ken
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
as in steering wheel loose? how do i tighten it - cos i wouldnt be surprised if that is the case :D
wheel.. as in allow wheels..
not ur steering wheel..
watch out..
coz it could fall off.. and do a lot of damage
Originally posted by tenzero
Thanks Ken will do. I prolly would have used the RAC if you hadn't said that...so good timing.
Cheers.
D.
The RAC will spend more time doing the
* rip in seat , mark on rear squab , dirty hoodlining type report which any schmuck can see by using there eyes.
The important , check front end play , compression or leakage test, check syncros and oil cond test are bypassed cos they are baffled by the lack of V and too many camshafts.
Cheers
Ken
Cheers
Ken
Nice, will keep all that in mind when I need to get one checked out.
Cheers.
D.
Wheel balance done last week - alignment done this week and the guys that do it are pretty good at what they do - so i ruled that out!
Well then they must have got it wrong then.
Have you hit any kerbs or suddenly heard a loud bang not long after the wheels were balanced ?
cheers
ken
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
