Originally posted by Nizmo
haha havent u had enough of me for one weekend paul? :D U saw it today its filthy if i dont do it then it'll be ugly and weird smelling (although i have either got used to it or its disappeared) for another week.
Quick question: My steering wheel vibrates at 80km and by 120km its shaking hella bad - its had a wheel alignment done but its still like this and its really annoying! Anyone know whats causing it?
Wheel Balance or your nuts are loose.
Cheers
Ken
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
as in steering wheel loose? how do i tighten it - cos i wouldnt be surprised if that is the case :D
wheel.. as in allow wheels..
not ur steering wheel..
watch out..
coz it could fall off.. and do a lot of damage
Originally posted by tenzero
Thanks Ken will do. I prolly would have used the RAC if you hadn't said that...so good timing.
Cheers.
D.
The RAC will spend more time doing the
* rip in seat , mark on rear squab , dirty hoodlining type report which any schmuck can see by using there eyes.
The important , check front end play , compression or leakage test, check syncros and oil cond test are bypassed cos they are baffled by the lack of V and too many camshafts.
Cheers
Ken
Cheers
Ken
Nice, will keep all that in mind when I need to get one checked out.
Cheers.
D.
Wheel balance done last week - alignment done this week and the guys that do it are pretty good at what they do - so i ruled that out!
Well then they must have got it wrong then.
Have you hit any kerbs or suddenly heard a loud bang not long after the wheels were balanced ?
cheers
ken
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
