Originally posted by Nizmo
haha havent u had enough of me for one weekend paul? :D U saw it today its filthy if i dont do it then it'll be ugly and weird smelling (although i have either got used to it or its disappeared) for another week.
Quick question: My steering wheel vibrates at 80km and by 120km its shaking hella bad - its had a wheel alignment done but its still like this and its really annoying! Anyone know whats causing it?
Wheel Balance or your nuts are loose.
Cheers
Ken
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
as in steering wheel loose? how do i tighten it - cos i wouldnt be surprised if that is the case :D
wheel.. as in allow wheels..
not ur steering wheel..
watch out..
coz it could fall off.. and do a lot of damage
Originally posted by tenzero
Thanks Ken will do. I prolly would have used the RAC if you hadn't said that...so good timing.
Cheers.
D.
The RAC will spend more time doing the
* rip in seat , mark on rear squab , dirty hoodlining type report which any schmuck can see by using there eyes.
The important , check front end play , compression or leakage test, check syncros and oil cond test are bypassed cos they are baffled by the lack of V and too many camshafts.
Cheers
Ken
Cheers
Ken
Nice, will keep all that in mind when I need to get one checked out.
Cheers.
D.
Wheel balance done last week - alignment done this week and the guys that do it are pretty good at what they do - so i ruled that out!
Well then they must have got it wrong then.
Have you hit any kerbs or suddenly heard a loud bang not long after the wheels were balanced ?
cheers
ken
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
