  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Cheers
Ken
Originally posted by GTS-t VSPEC
Ken,
I keep bouncing off the limiter, I never seem to get to 120 in first:D
Niz, Keep hanging around with Ken and you'll soon learn all the old dogs tricks:D
See'ya:burnout:
Yes but I'm sure loz can show old dogs new tricks.
* did I just say that *
:):D
no it was a scientific test i was undergoing there - how much stress and agitation can joe take :) god i freaked him out a couple of times that day haha i think we are going to have to set up a SAU trauma unit just to take care of car whorers such as Liz and Joe hehe
Niz,
I think you scared Joe, but I knew you were in complete control:p
See'ya:burnout:
Hmmm , still gotta pay out on Joe some more over that.
Make him feel really bad . Hehehehe
Cheers
Ken
Niz,
See'ya:burnout:
aidwin said he's only seen your race face til that day and then he saw your shame face haha :bahaha:
I was in complete control - friggin lucky it didnt lock up and me going sailing thru anyway.
Well you won't need it for Kyles .
Her comments while we were hunting whales was that I drove MUCH faster than troy and then started laughing.
I was scared and she was laughing. Boy , some redheads are hard to scare !
Cheers
Ken
Race face , shame face.
What did I miss ??
Cheers
Ken
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
    • 310mm rotors will be avilable from Australia, Japan, and probably a few other places. Nothing for the front can be put on the back.
