  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Niz,
There isn't much hope, they own commodores and flying ducks. your doomed:p
See'ya:burnout:
Can just see it in 20years.
Chenille curtains , lino in the kitchen , big hairdo and picks of Peter brock on the fridge, 5 snot nosed kids and one in the oven with the hubby driving the fool sic ute mate.
hehehehe
Kill yourself Niz
Kill yourself NOW:D
Cheers
Ken
like one of those duck mating call whistles they sell at the markets ken.
Paul yes they are sad - but since i look nothing like my dad theres a good chance im adopted *pls god make it so* haha
yea , you wouldn't look as attractive with a 5 o'clock shadow
Cheers
Ken
The sad thing about that Ken is - my mum actually tries to chat guys up in holden utes for me. The odd occasions she's in the car she goes " quick catch up to that ute" im like why? "cos mostly guys drive utes and he might be single" hmmm yes what always wanted a BnS king.
Niz,
Adoption has always appealed to me:D
Ken, I hope you carry tissues for when you dog :spew:
See'ya:burnout:
Paul there are only 2 types of men in this world
Wankers and liars
Cheers
Ken:D
What , she thinks your that unattractive you can't pickup guys by yourself.
Change that
Kill your mother
Kill your Mother NOW
Cheers
Ken
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
