  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Paul who says u have to be drunk haha
Yeah im not that serious ken - but i dont like for the wrong impression to be given out either. I think as the close group of mates we are theres no point in making a scene to embarass everyone involved - if he tries it on again he's dead tho. Apparently im not the only one joes had a grope of tho :)
Originally posted by Nizmo
No Macka didnt get a feel at all - dont know what pauls on about now :)
Oi paul with the shirts - im comfortable in a medium but dont know whether the sleeves look alright or not - dont want to get a large incase they are humungous.
We were sorta hoping the ultra small super shrink when wet one was gonna be the go .
Ohh and enter you in the Autosalon wet tshirt competition as our SAU representative.
with Kyles as backup.
cheers
Ken
haha i would be using me as back up - kyles would win for sure!
yea , you stand behind and it wouldn't matter.
We still get to see allt he best bits.
Who said being 6'1" was a handicap .
hehehehe
cheers
Ken
thank u paul im very flattered they are pretty nice shirts - do agree logo needs to be a touch bigger.
Wonder whether the shrink or stretch in the wash? haha
Please say they shrink.
btw Niz , check your pm
Cheers
Ken
Originally posted by GTS-t VSPEC
Niz,
Yes, the next lot will have bigger logo's, we weren't sure how big to go at first. The proper girls one will be black.
See'ya:burnout:
Dammit pail.
Niz was modelling and you were too busy drooling to take pics ??
Gees next time , call me and Troy the porno king.
Cheers
Ken
Ken,
That's nice, keep secret's from me, I am the only other person here:p
Try not to use the choker chain:p
See'ya:burnout:
yea but when yours will fit through the links , it doesn't matter does it ?:)
cheers
Ken
