  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by SHUTO-BOY
or get an n/a 1.8 4g92, and put on a mivec head/ecu
thats what i told him. he wanted to just do the 4g15. snapped him out of that fast.
paul - yea. i dont want to act like an adult, thats why i took the whole weekend of work just for my party. 2 day party bring it on~~~!!!!
Psiker
Originally posted by Psiker
also. a freind of mine asked this of me. could u guys recomend someone to do a 1.8l mivec conversion to a mirage? i tried to sway him from it but hes hell bent on it as he love mirages!!!!
Psiker
Try Mal crockenberg
Crockenberg Motors
John St
Welshpool.
Is the Ralliart agent in W A and has done that conversion to a colt or something similar.
I believe is a bit more work than you think.
Cheers
Ken
Originally posted by Nizmo
i feel like wine tonight. :P my cats gone to bed without me - the bloomin thing sits at my bedroom door and howls til i let her in - she loves sleeping on my spare set of skyline floor mats - the cats got taste!
wine........ xanadu!
cat- do you have photo of your mossie?
Originally posted by GTS-t VSPEC
Psiker,
I'll see him tommorow, I'll ask him who much, but it is never cheap to do a conversion:D
See'ya:burnout:
mmmmm. he was praying after the drags that the box was farked ne way :P is leaking tranny fluid everywhere and skipping from second to third for no reason. he was runnin constant 15's wit 3 second 60 foots. but a terminal speed of 157kmph
Psiker
Originally posted by osc@r
Ken,  it's a sr20det silvia..
jumps out of reverse, feels like it's not fully selecting it.  All other gears feel perfect.
Only done 70thou k's.
Does it go into 5 th further than 1st or 3rd ?
Cheers
Ken
Originally posted by gtrken
Try Mal crockenberg
Crockenberg Motors
John St
Welshpool.
Cheers
Ken
thanx ken ill tell him. i rekon it would be pretty hard also. but he has the cash to burn and really wants to do it. so i want to send him to the right ppl. dont want im to get too stuffed around :P
Psiker
Niz,
What word would you use?
See'ya:burnout:
molest :P
Joe i'll see if i can dig up a photo of zenah - she's just a tortiseshell moggy tho - but she's god damn smart - too smart for her own good!
aidwin yeah i like sweet white wine - not too fussed on reds - but they say u acquire a taste for red when your old haha wine leaves u with a shocking hangover tho.
if you like sweet white wine then no doubt you should try the noble rising from Xanadu or Pikes.
red = :spew:
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
