  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
yeah, CC's grammar guide is a little nit picky, I don't mind common short forms or lack of case. But these guys are a special bunch. Check out their "Required Reading for The New Guys": http://corner-carvers.com/forums/showthrea...p?threadid=7393 and "Zero Tolerance Week": http://corner-carvers.com/forums/showthrea...p?threadid=6324
Gold, I tell ya :P
"Some of you may be repulsed, shocked, and horrified at what mayhem ensues from this, but my only words of comfort will be SuckIt! If we piss off a thousand to get fifty more like us, it will be worth it."
I'd like to see SAU implement Zero Tolerance Week.
Nah, I don't post there. Just lurk off the suspension tech.
    • No. The castings are all the same. As you have the inlet off, simply measure the diameter of the inlet ports and compare with the freely available on the net sizes of turbo and NA. The NA ones are small.
    • Hello everyone, I'm glad to join you.
    • Definitely do-able haha. I will give it a try if the fuel pump hanger does not solve the issue. Just need to find some quiet time in the area, Malta is like a big city and I live right next to the main hospital so it is very busy during the day. I'll be installing it in about 2 weeks, found a garage that is pretty knowledgeable and has the necessary tools. This garage has worked on multiple builds, even for competitions. They even asked me to stay with, so I should be fine.
    • Just to add, I found the r32 gtr ecu the most forgiving, the r33 one would get the shits.
    • For what it’s worth I drove my gtr for over a decade with gt-ss as a true daily after I pulled off the -5s, I had it engineered and went with stock ecu etc.  never skipped a beat.    I would only worry if you can’t get good fuel all the time in a tropical paradise
