  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
*Leaving lurker mode*
Morning..... I have a trade off coming up shortly..... At the moment I have an office to myself but with absolutely no view, and in a few weeks I will be going to the top of QV1.... Great view of the river and city but will be open space planned in the O&M room so no more privacy.... means I cant sit here chatting away freely anymore :P
