  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by skyzerr33
fine
missy u can't get a lift get on the train and i'll get u from the train station
just to please ken
and jason the book will be fine
What !! ??
Masteryodeller is gonna let his dearly beloved with the voluptous charms travel unaccompanied on a train from Joondalup at night.
shame yodel , shame.j/k:D
As joe said , pick her up ya cheap bastid. hehe
Cheers
Ken
Originally posted by gtrken
What !! ??
Cheers
Ken
u want your money after this pay or next pay?
Originally posted by Psiker
in fact like ive said b4. ever go to amf rocky. ask for paul  and if im there  mention ur from SAU perth and ill get ya a good price :D
Psiker
I sometimes make a trip to rocko bowling. that place got burt down.. or was that next door :confused:
If I could guarantee I am coming tomorrow , I would pick her up.
If she has to catch the train , pick her up and pay me next pay.
I hate night train travel and I would think that Kyles would by herself too:D
Cheers
Ken
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
