  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by gtrken
If I could guarantee I am coming tomorrow , I would pick her up.
If she has to catch the train , pick her up and pay me next pay.
I hate night train travel and I would think that Kyles would by herself too:D
Cheers
Ken
thats mid may u may forget by then hehe
kyles loves the train she flirts with all the guards
Eiw troy your brother is a gard. And heven help anyone who would try anthing on me will deffently regret it.
Trains are pretty safe at night. I have never had a problem. Its not like its at 2am in the morning (and its fine to catch the train home by my self then too.. ive done it lots of times). its 8pm. Pretty safe!
theres cameras and stuff on both trains and buses now so u should be alright :D
Psiker
Originally posted by skyzerr33
see ken she doesn't even want to be in my car :D
Ahhh , you may be a yodel meister but have still much to learn about the female species grasshopper...
Cheers
Ken
