  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Adrian_perth
neo, thought i'd give ya an idea as to what i am getting for my new exhaust :- hks hiper/blitz nur spec catback system
                     :- 3 Inch Highflow cat
When you gettin that Adrian. Will be good to see some at the cruz. I swear people must think that i steal skylines. I look under then all everywhere. freak!
i do it all the time. or pull a hard u turn while im driving to go and check a good looking import out :P
i love the funny looks u get :D
Psiker
i don't have it yet neo, but if all goes well i have my plans set out and mods should start hopefully next week if all goes to plan :D
at the moment i only got blitz filter, apexi front pipe and trust catback getting rid of front pipe and catback for new shit though :P
adrian :D
im turning 18 in august :D it's hopefully gonna go hard! i seriously wanna change it to manual but then again i'd get a better time with the slush box :P and maybe if i get that new turbo it will go even harder :D
adrian :P
wow RESPEKT!:uh-huh:
when i was 17 i had a 1991 TR magna, Auto, 2.6l 4 cyl
did u get the loan and all urself or buy outright with savings?
Psiker
adrian :D
i thought apexi front pipe was good though? or u just want it to be the same the whole way thru?
Psiker
the catback is shit i cut on resonator and middle muffler sounds alright but i done like the welding and shit looks dodgy the muffle is tiny inside as well
apexi frontpipe is meant to be good, but it's only 70mm i dun think that is 3inch :P
adrian :D
my parents GOT the loan for me, BUT i am paying for everything, i was too young to tak out a loan so just got them to do it, no way would my parents pay for it :D
adrian :P
wow nice parents. my parents will go gaurenteer me (speling) but they wouldnt take a whole loan for me. specially with the houses and cars and the boat (now gone :D )
Psiker
    • If you mean the alarm immobiliser; theyre internal to the alarm itself which makes that difficult; I couldnt even see where he put it; its not in the same place as last time; but with all black wiring it might be very challenging to trace  I had someone turn the key for me as I know it only primes for a couple of seconds As my post above; I am getting no voltage to the pump at all; but I am testing continuity of the power line (SB) from the pump plug to the relay fine. As well as the negative from the pump plug to a 12V constant.    Yeah; he blammed the no start on a bad battery; said I needed to get a new battery and it'll start. Turns out the battery drained because the tail lights had been on for half the day during the install (the rubber cushion on the brake switch gave out while he was testing it as I have a picture of the car from that morning with the tail lights off..i've replaced that). The battery was turning over the engine just fine for a long time; but got low since lights were draining it so it was too low to test a start after he finished. I bought a new one on his advice...$250 wasted. My original battery charged up just fine and is healthy.    It was running perfectly fine when I messed up the old alarm (programmed out the remotes). He couldnt start it after removing the old alarm; my assumption is that when he unhooked it; he didnt bridge the circuit back when trying to start it. Its always been perfectly fine. The ECU swap and pump were 2 years ago. It's never missed a beat in that time.
    • This is a big issue for me without the diff. I just have zero drive from the passenger side when drivers side has no traction. Bec's parents place has a crazy steep driveway with odd camber and I have never been able to get up. My bro-in-law's 130i with an (unknown brand) LSD gets up fine as does their dad's Hiace. My car stays at the bottom. We have other odd camber roads around here as we're elevated a bit and if it's raining I can get totally stuck around some hairpins.
    • Yeah, I am super excited for this.
    • Was the car running before he touched the car?
