  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Everyone has those Louis Vuitton Handbags :)
Scott and I were shopping in subiaco spied this versace top - which i thought was fag richboy looking but anyway - had a price tag $1500 haha you would be pissed if u got grease on that one :)
Originally posted by caminperth
joe - i know that.. i think my other half has the record for the most expensive handbag.. put it this way - for the price i could buy a NEW turbo!! *sob*
you damm right you are!
Those LV scarf can buy you new tires
Those LV glass case can buy you new ECU
Those LV hand bags can buy you new IC & Turbo...
and set of travelling bags can buy you R34 GTT
:bahaha:
i have two handbags both about $25 - even i think thats too much on a handbag! My most expensive purchase in clothing was a $300 evening gown. Refuse to spend over $150 on an item and then it has to be something REALLY worth it!
joe - tho unlike you, i didn't have to spend the $$ on it.. but watching it happen was enough to make me cry...
heheh you lucky dog... you didnt get sucked in :)
well I did :) No regrets but its a lota $$$
have to ask yourself, if that is worth it!
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
