  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Everyone has those Louis Vuitton Handbags :)
Scott and I were shopping in subiaco spied this versace top - which i thought was fag richboy looking but anyway - had a price tag $1500 haha you would be pissed if u got grease on that one :)
Originally posted by caminperth
joe - i know that.. i think my other half has the record for the most expensive handbag.. put it this way - for the price i could buy a NEW turbo!! *sob*
you damm right you are!
Those LV scarf can buy you new tires
Those LV glass case can buy you new ECU
Those LV hand bags can buy you new IC & Turbo...
and set of travelling bags can buy you R34 GTT
:bahaha:
i have two handbags both about $25 - even i think thats too much on a handbag! My most expensive purchase in clothing was a $300 evening gown. Refuse to spend over $150 on an item and then it has to be something REALLY worth it!
joe - tho unlike you, i didn't have to spend the $$ on it.. but watching it happen was enough to make me cry...
heheh you lucky dog... you didnt get sucked in :)
well I did :) No regrets but its a lota $$$
have to ask yourself, if that is worth it!
    • A few random issues have popped up since my last update. My WMI pressure sensor failed within about 10 minutes of it seeing liquid. It was a 20$ China special, so I'm not surprised. My name brand replacement should arrive today.  My power steering assist also decided to crap out last weekend. The usual, works for about 60 seconds after starting the car then I lose it. I dusted off my old copy of NDS and connected to the HICAS ECU. Code 4 for assist solenoid.... I tested the solenoid and it's fine.  I knew the day where my HICAS ecu would crap out would come, and I welcome it. It was the last HICAS part on the car that is now in the bin. I've ordered an SSR and I will control the power steering solenoid with my Haltech ecu. It will be nice to have proper speed referenced assist again after all these years.
    • Haha I just finished the last season of TPB: Jail last month. I'm happy they're still pumping out episodes.
    • We want to see pictures of the carnage!
    • The picture of the underside of that PCB shows either old flux that wasn't cleaned properly or some other contaminant (I.E Water). I would flush it with ISO and try again.
    • @silviaz Are you skim coating the entire panel (covering the entire panel with filler) before your hitting it with the long block? Or are you selectively applying filler to the repair, trying to fill the low points?  Please don't do that.  Almost certainly. Are you checking the panel for flatness as you go? Or is it more a case of, sand til all the guide coat is gone then check?
