  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Neo
I though that C-red did there own compliance? I saw a new silvia that they brought in at another shop? Anyone?
Ken,
can we see you in action at any of the tune days at waneroo?
They only hold compliance for a certain range of cars.
Blue S15's aren't one of them.
Cheers
Ken
Originally posted by GTS-t VSPEC
Neo,
With the new rules then most people won't be able to do the compliancing, only accredited workshops:D
Ken, Sure, another pointless thread can't hurt:D
See'ya:burnout:
Hey if eriktosser can get a thread on freek ( or *****ng whatever) , the Troy has to be worth a little bit of bandwidth.
Cheers
Ken
Ken,
I don't do Wanners pers'e but when the Enjo SES goes there , then I will.
I am hoping the SES Collie circuit and Wellington dam on the 26th -27th April is my next one.
Cheers
ken
Hehe, It's a pity erik didn't show last night, I had a few words of advice for him:D
Why don't you start the thread, you scared?:D
See'ya:burnout:
Advice like
You , your mate , your dog , your horse , your bbq AND your skyline and it's plates , F**CKOFF !!
Cheers
Ken
Ken,
If I'm free I'll try and make it down, will you have the 4WD to toe it by then?
See'ya:burnout:
Yep , I already got it.
Picked it up yesterday.
Gotta love the petrol guzzling maverick/Patrol.
Cheers
ken
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
