  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Haha Liz nah that went on the full length cruise on sunday but i didnt go cos me and my friend decided it was a nice day we would go down to the leftbank which we did and after a couple of hours and a few drinks we decided to check out the Cott and at that stage my best mate was getting me a little smashed even tho i was driving and i messaged paul to see if the guys wanted to come and join us after the cruise so him and aidwin rocked up.
if i cant whore a lift I will resort to being good Liz and come n pick u up :)
Ive converted my dad to Nissan me thinks. I went out to dinner with the olds tonight and on the way home mum was talking about dropping her car into service and told them not to give it back til they have it fixed (my parents own VX clubbies)
Dad says - well if its anything like our repairs you might not have it for 5 weeks
Mum - thats ok I'll ask for a courtesy car but i dont want anything im going to get laughed at in
Me - Mum you drive a holden you should be used to being laughed at by now
Dad - *cracks up* thats very funny lauren i like that - hey isnt there a nissan dealership around here somewhere lets go have a look :)
Me - might be an R34 in one of the import places
Dad - REALLY? :) hehe yep he's a convert!
nah cant have that - i think i may be able to squeeze dad up for some mods if i stay single and batt my eyelids and be a good girl. I know he's just itching to spend money on my car so he can show off :)
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
