  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
drew said to me today that if I get a skyline he better be allowed to drive it more than he got to drove the 180 - and I was like "get f*cuked - you think your ford is all that and a bag of chips - so if its so good why do you want to drive my car"..... then there was silence and a "shut up liz" hahah i also called him a trev on the phone to Paul... nearly got kicked out of the car for that one
prude = english aidwin hahaha :)
Thats ok Liz u have fights with your guys when u first get your car I was all excited when i first got mine rang him up and got "My supra is going to be sooo much better" Grrrrr
Originally posted by Pva_Glue
Saw nizmo racing (more like :burnout: ) with Honda civic at the corner of st george's terrace and william street hahah...
Civic was reving his engine hahah :bahaha:...
Niz slowly took off then, she looked and laughed at him!
but Civic kept reving and took off with mighty front wheel spinning.
I guess other car drivers does that with skyline or maybe its skyline plus chick factor :confused:
I waved to niz but she didnt see me or she ignore me :( I was in my boss's BMW 3series...(321i or somethng) taking out for spin :) (actually taking car for servicing :))
cheers
Joe
Hahah sorry Joe i didnt see ya - i couldnt let the opposition see a smile or any other signs of weakness :)
God bless little civics that make me look good!!
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
