  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
well must go as i have guests
Sleep well boys - after serious lack of sleep i dont think i'll rise til about 1pm tommorrow - anyone up for a leedy sunday sess? been thinknig about thats where i may head.
IT's 3:35 AM just got back to mate's place :P
we had great fun! no didnt go to Strip Joint after all :(
arrhh well more naked people were walking around the north bridge though :)
went to church then VAGA then Metro city....
about line up for the damm RISE but waste of time... it was fully packed! hahahahah.... songs were good from outside too :P
Good night all ;)
ps. Met white R34 John... and Bayside Blue R34... Nice :D
also I was dancing with gail but damm her X turned up ruined the fun :( bastard! :P
cheers
JOe
