  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
yeah i been looking at the positives, but the hardest part is that we work together :P
i have more money for mods = Postive number 1
noone to cuddle up with for winter = Negative number 1
noone to spend special moment wit = Negative number 2
looks like negatives are winning :P
adrian :D
Originally posted by Adrian_perth
hahaha oooooooooooooooh well lolz u know what jason(neo) hasn't specified if he wants just ex.gear or full set, should i just assume he wants ex.gear and place order with brent?
adrian :D
go ex.gear and place order
or don't include him and place order
he can then buy mickos current ex.gear if he wants one.
hehehe
hey how much did ur power fc cost? if i dun have enough for wolf i am thinkin of trying the emanage hey but i dun think many tuners are familiar with it? i mean they get better results with it in japan?
adrian :D
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
