  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
yeah it's cool hey, no use moping around but it's hard not to :)
i dun wanna get involved again, wayyyyyyyyyyy to much hassles :( excuse me while i go spend some money on my car :D (the only good thing that came outta breakin up) :P
anyways enough moping, paul do u reckon e-manage any good?
i wanna give it a try i read so much good shit on it but that in japan, i dunno anyone in perth capable of tuning it, troy said lumpy has done a few?
adrian :P
hahaha niz, i wouldn't go that far as putting a big gay wing on my car! :D
I ain't gettign gt wing anymore :P getting a different wing
ooh ooh ooh and in a moment of sadness i went out and splashed some money on a new digital camera! :P
adrian :)
niz, some of the big hp jap cars are using not a full ecu system but piggyback greddy e-manage and they are getting some awesome results with it :P if i can find someone who is capableof tuning it without destroying anything in my engine i might give it a go :D
adrian :P
Originally posted by GTS-t VSPEC
Why don't you sell the horse and buy an R31?
See'ya:burnout:
There is many reasons for that Paul see, I couldn't get enough for my horses at this stage as they are young ones being schooled up and trained into being worth lots and I love my horses. They show affection like nothing else!
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
