  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by 87vlt
what tablets are we talking here?
What u got?:bahaha:
I had my fare share when i was young but i have had enuff of that seedy underworld to know where it can lead. I dont take any of that crap anymore and ill rarely even take a panadol unless im really bad or have a fever or something.
I really dont trust presciption drugs either seeing as its usually a trial and error process.
"hmm take these for a month and we will seee how u go"
"ahh i feel funny"
"thats normal but take less"
etc etc
Alot of doctors dont know their stuff. Specialists all the way for me, wether it be a cold or an amputation. Sure alot of them are trained ok but experience makes the difference.
All those anti depre4ssants just screw with your bodies natural balance and imho just 1 month of using them can screw your head for life if your susceptable.
Well thats all i have to say about that
Guest 87vlt
Originally posted by Boostzor
What u got?:bahaha:
"ahh i feel funny"
etc etc
dude settle we were talking presciption drugs. I wouldn't touch explicit drugs.
Guest 87vlt
Originally posted by GTS-t VSPEC
Hehe, Matt I might need some of them, I get very angry at slow drivers, and I tend to speed everywhere:D
See'ya:burnout:
even better ban women from driving 4WD. that'll solve a lot of problems. damn corn feds wives in their husband 4wd ..... they give me the poos ....
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
