  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Hi peeps , not here long , am shattered.
pwptpf , yellow sticker eh?
Aidwin , owner of Aust's lowest Km Skyline ( cos if it's on the road , his lic ain't )
Kyles and troy , grumpy and co.
Cheers
Ken
Good Rally for Maximums , Rob won and the eye doctor took out 1st Novice.
Brad run out of fuel ( don't ask )
and Neil crashed ( but not too bad )
Rob was behind by 59secs or so going into the last 2 stages but beat the evo3 of Bignall and the evo7 of Dunlops to win and also take out Group N.
Cheers
Ken
yea Mandee the great said that the cops were a major drama.
Notice thet the Japspec cruise was a disaster as well with no one finishing it.
Glad I did the brownie point thing and went for tea.
Cheers
Ken
Originally posted by GTS-t VSPEC
Ken,
Sounds like a good event for Maximum then:D
See'ya:burnout:
Yep , went back to the Donnybrook motel with 4 ctns of Cougars and Black Douglas and cola . I gave it away at Midnight when we all went to bed after shooting shit .
Cheers
Ken
Ran out of fuel? Hopefully from a punctured tank and not someone forgetting to fill the up:p
See'ya:burnout:
Faulty fuel gauge and a Navigator who wasn't thinking properly.
The other rexes in the team were asking for 30 and he said only 15litres. Was queried about it by the fuel man but insisted he was ok.
Navigators responsibility. Nav is now looking for someone to blame....
Cheers
Ken
Ken,
Yeah, wouldn't want to spoil your perfect driving record:p What happened to the JapSpec cruise?
See'ya:burnout:
Perfect driving record ?? wtf ??
In the performance forum read thread re. Japspec cruise 6.
Not sure , bad instructions , illiterate people , cops , all of the above , none of the above . Am not sure.
Cheers
Ken
Oh well, sounds like the team did the right thing, can only blame the navigator. You live and learn:D
See'ya:burnout:
yep we all got a job to do and he stuffed it up but won't admit it.
Have had the request to replace him but am told by the team owner he needs me under , not in the car.
Dammit !!
Cheers
Ken
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
