  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
You want to be a navigator? Do they get paid or do it just for fun?
See'ya:burnout:
Paid ??? hahahaa
No , just for fun , glory and Trophies.
btw , the trophy for 2nd o/r at Wellington was a big GT3 porsche. Bugger !! no F1 car.
Cheers
Ken
Would appear that Steve ( SST ) and Mr winfield look alike Gray in the GTST had a bit of falling out.
Was speaking to Steve and he said that a smaller turbo was fitted cos Gray was blaming that.
Cheers
Ken
ps Wholagan is still waiting for steel forks for the ppg box.
Did you see AJ drive today? He didn't get to do many laps.
Who's second in 4WD? Seymour?
See'ya:burnout:
Supposedly has 450hp atw but doesn't seem like it. Is the JUN engine but with a supercharger.
Engine was getting hot so AJ parked it. I would too knowing the cost of that motor.
Cheers
Ken
Yeah, I spoke to Steve a fair bit, won't go into details on what he thinks of Gray:D His little Datto was doing alright for it's first run.
Steve Maitland was going well until he went in too deep on the last lap.
Spoke the Graham Stones, his car was flying, but has got gearbox problems.
See'ya:burnout:
See'ya:burnout:
Caratti made a few enemies when he had a coming together with Anderson ( Racetune prepped Escort ) and Matt Cherry in the red RX7 that hit the wall.
Cheers
Ken
    • Just to be clear, there were no lights or codes when the hiccups were occurring. Also nothing noticeable in the cars' braking. It brakes fine and the dash is clear. I only made the connection when it did throw a code and suddenly, despite the lights, it felt great again.
    • Yeah they are sliders and this was in my head before I worked out it was the speed sensor.
    • Ok so we have a smoking gun.  A few weeks ago I had to replace a speed sensor that I'd fit incorrectly. I replaced the sensor and everything was fine with no lights or codes thrown any longer.  When I was doing some more bedding in yesterday I got ABS and traction control lights again and, considering when this happens those things are disabled, the pedal went back to normal with smooth braking and no hiccups.  The codes thrown are for the same speed sensor that I replaced. When I looked at the sensor I took out it looks like the tip of the sensor is damaged. So whatever happened to it, perhaps it has damaged the magnetic ring on the bearing (that I only replaced the other week). I'll get my boroscope in the hole where the sensor goes and see if there is any damage in there. Hopefully just the tip of the sensor is in there and the bearing is fine. 🤞🏻  It's worth noting also that the pedal hiccup happens more often and for longer periods now and totally goes away when the codes are thrown again which happens usually after 5 or so minutes of driving. Love all your help here as usual guys, thanks!
    • Could you put a real seat and harness in instead of what looks like leaving your passenger balancing on a milk crate
