  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Yes, Aaron was a little OTT with his driving at times. Anderson is a good driver and didn't need that. I'm not sure if the RX7 was also to blame, hard to tell from my angle.
Seems that Kerry Wade is still holding on though.
See'ya:burnout:
Matt was on the line but a little behind.
Aaron should have given him some room , hit so hard that the RX7 bounced over the inside kerb and broke the LH lower balljoint which is what put him in the wall.They aren't playing for sheep stations and he will get a reputation like Mitchell where everyone will suddenly gang up on him.
Cheers
Ken
Cheers
Ken
Will the Lola be able to make up enough points to win the championship?
See'ya:burnout:
Don't know but I will have to come 2nd or 3rd to keep my chances alive.
Cheers
Ken
Hehe, you dirty man Ken:p Don't worry Kyles:D
See'ya:burnout:
Dirty , why so.
You guys discuss the female form and it's banter and flirting.
I discuss it and it's dirty:D .
Cheers
Ken
Ken,
Do you know what happened to Shaun Ferrel's car? Seemed to blow alot of smoke all of a sudden.
See'ya:burnout:
O ring on dipstick tube and a slightly over filled sump.
Cheers
Ken
It's dirty cause you an old married man:p
See'ya:burnout:
nuff of the old whipper snapper.
Least I got all my points and no yellow. There is something to be said for appearing old and respectable when stopped:p
Cheers
Ken
    • I see what you mean on that last paragraph and makes sense. I am leaning towards because I made the repair/filler area large that I didn't use a long enough block. Will minimise the area and let you's know how I go. This is random but I noticed when I put epoxy primer it felt flat but that's just temporary.
    • Tried to repair with filler only. The block is a foam block but quite hard and I put a velcro on it for sandpaper, the hook and loop system. It's not one of those super soft ones that just follow the panel. Similar to a dura block.
    • You need one of those automated sprays that puffs a nice small every 15 minutes in their room. Except swap the nice smell for chloroform...
    • Don't step down power supply size, maintain it the whole way. It's how I'd do it. OR, Id have one feed, with one joint that splits out to six smaller gauge wires that go to each coil. I wouldn't add joins like stepping from 12 to 16, at the first two coils, as if you try to continue that fashion, each joint will introduce a voltage drop. In theory, earths should be the same size as power feeds, however in this case the main power needs to be bigger due to the average size current. So the next question is, how much current do these coils actually need?
    • I think Murray is onto it. It's sounding like either it's a soft block, not long enough block, OR if you're chasing waves, you're going in the direction of the waves, instead of across them. Rotate your sanding pattern by 45 degrees is something to try. You said you're going in an X, so now instead, from the same perspective, do a "t" instead.   If you're not able to have the block sit on top of two high points, and not touch the low point between them, you'll never get it flat.
