  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Hey dudes, gotta let this off my chest
cops suck dick, i talked my way outta a yellow yesterday and gave them a ripe all talking to, the embarressment of getting pulled over with ur mum in the car, good thing is mumzy got involved when i was saying a few words to the cops about how stoopid they are! pissed me right off 4-5 License checks in just one and a half weeks approx! not a happy camper
adrian :P
THE BOY'S PRAYER
Our Beer
Which art in bottles
Hallowed be thy sport
Thy will be drunk
I will be drunk
At home as it is in the pub
Give us each day our daily schooners
And forgive us our spillage
As we forgive those who spillest against us
And lead us not into the practice of poofy wine tasting
And deliver us from Tequila
For mine is the bitter
The chicks and the footy
Forever and ever
Barmen.
yeah, the ones that pulled me over hahaha i bet ya they wished they hadn't lol lets just say i questioned them why they pulled me over and they were like to check your license so i said why me though and he was like i dunno i choose who i wanna pull over,
adrian:- yeah coz i got p plates and it's a japanese car?
cop:- (no answer)
cop:- i've pulled over about 10 cars today
adrian:- i just passed you pulling out of the police station?
cop:- i've gotta go, have a nice day
adrian:- mumbles thanx for wasting my time
in the meantime mum is having chat to the other one heheheeee asking wats the point
ahh feels so good to leave cops speechless :P
adrain :P
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
