  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
red or silver i allow but no fluro pink shall adorn my car!! Paul if u really want some i will get u some - hell it cant get any worse now can it? hehe *niz hides :( *
Adrian - nothing exciting hun - tune and general service and hopefully finally fix that annoying idling bullshite problem!! Should get a bit more power out of it - apart from the occasional bursts lately my cars been a bit sluggish. Cant afford anything else just yet - saving for a front mount intercooler me thinks
paul - thought that's what u were talking about.. never heard them called anti roll before tho.... yea - they should make a huge difference...
i hope it's easy to fit them to a skyline cause i'm very interested in doing it myself.. is it worth getting it aligned at wheels world afterwards? they charge $70 or something?!?
Easy to do yourself , won't need a w/alignment cos you are not changing camber , castor or toe.
Wilkinson Suspension do 4 wheel w/align for about $50 anyway.
Cheers
Ken
niz - who's doing the work? i take it they have gay stickers?
ken - mmmmm.. circle work.. need to learn how to do that properly soon... :(
anyone know who teaches at the mc motorsport days? The one where u drive the mr2... had quite a run in today with the manager of mc cause he cancelled my booking.. so we're going next weekend...
paul - thats what i thought... tho i guess they gotta pay for the equipment somehow... no_respect has some spring compressors that i was going to hit him up for.. as for the rest of the tools - i've got a fair amount that should be able to do the job...
ken - thanks for the wilkinson suggestion.. will check them out once it's done just to be sure..
West Racing is doing it Cam - yes Tim puts gay stickers on my car - fluro pink cos im a girl :( cant he see ive got a colour scheme going haha!! mmmmmm soon to have red brakes mmmmm red!
Paul i wonders what happen if u just take the sticker off - do they actually record what cars have stickers and chase it up with the traffic dept whether they have been or not - always wondered how the system works!
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
