  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by G0DF4Th3R
ah see thats whut im worried abt...i dun mind paying more for a dump pipe if its a better design...
what are the chances of getting a yellow if i have a screamer pipe like adrians?
hahahaa, they won't find shit :O unless they crawl under the car ;) hehehehe but then again i'll have my stocker on hand just incase :P which will be nusiance :P
paulie, you busy tommorow morning? i need sumone to bring me back from xspeed :( then i also need someone to take me back to xspeed in afternoon to pick me car up :(
adrian :P
bambam, the wastegate doesn't open till it hits boost :O so as long as i don't hit boost around cops they won't hear it ;) coz the wastegate will be shut :P dun worry ive worked it all out :P and it's definately not gonna produce any turbulence coz the wastegate gases going out to atmosphere :P just turbo gases going through the system i can't wait to hear it, and feel the diffrence everyone speaks of after they put a dump on :(
adrian :(
    • Absolutely could be. I collected data logs from when the O2 sensor was still out and also after I had replaced it so will try to compare them. Pretty confident that the affect is lowered with the new sensor, will check logs at the same RPMs/conditions.
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
