  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Kyles
not really but he did a little 'sing along' to the radio on the way home.
Was it Naomis choice of song? Would have been Led Zeppelin. God that woman has got good taste ( except in Husbands ) Hehehehe
Cheers
Ken
Originally posted by Nizmo
good evening all? :D
Evening Niz and thanks for the party invite. Had a good time and cos I was sober when I got home there was no problem.
I see that Mel didn't improve as the night went on. I bet she drove the porcelain bus a few times. Hehehe
Cheers
Ken
yeah she drove it in the morning - haha geez she makes even me look sober :D oh well its better her be drunk otherwise shes really normally quiet.
No probs for the invite - thanks for your company :)
Happy birthday Troy
Hello Kyles
i had controll of the radio ken :D hehe.. Nothing on at that time of night
Hi niz,
Troy get your birthday arse on mirc :)
Nite Cam.
You 2 off for some private internet sex and flirting.
Why don't you stay here like before?
Cheers
Ken:D
Hmmm , then Mel must have been well on the way when I got there cos she wasn't quiet then and that was only 8.30 .
Would have been fun to stay and stir her up but alas, the trouble and strife beckoned.:D
Cheers
Ken
Internet bonking, na he can hold out untill the weekend :D hehe.
We are going to see "he died with a falafel in his hand" on friday night :)
A WHAT in his hand ??
Cheers
Ken
yeah well what happened is she got there at 7pm with chantelle i just got out of the shower at that time cos i had a nanna nap before and i then realised there was cooking etc to be done so i was running around like a chook with its head cut off and my friends decided to instead of helping on my birthday they would watch me and start drinking. So i didnt start drinking til just before ken got there :D
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
