  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
ken - impressive list.. :D
aidwin - i don't think i'm the person to be teaching anyone anything to do with driving! tho after the understeering and conering lessons with ken i feel i have improved quite a bit.. much more comfortable when things step out anyhow...
night Liz
haha i found it hard saturday when u have your normal patterns of driving and ken is telling u to do one thing but your brain is telling u to do another cos its just what u normally do :D
Originally posted by SHUTO-BOY
wow drift series- id go watch it,its a nice sport to watch
Watch , dammit man , ya gotta have a go.
Put the crap tyres on the rear and a mechanical type LSD , bit of negative camber in the front and your there.
Cheers
Ken
PS Nite Liz , I think theres an all female day at MC on July 12th.
Originally posted by Nizmo
night Liz
Yuor normal pattern. That gearstick / shifter certainly gets some attention...
hehe
Cheers
Ken
hehe oh well gotta have at least one knob i can play with :D
just when started at new town i got used to driving prados and other manual cars so now even if auto resting my hand on the shifter is just what i do :)
mechanical lsd<-- so its easier to correct the car after you go sideways?
Nope but it's easier to get it sideways.
I got a 1.5 way cusco locker thingy in the back of Ricer and that goes sideways REAL easy. Ask micko , Cam or Niz.
Cheers
Ken
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
