haha chaos meant to sound that way :P
Alex - birdies like black too - so do wattle trees like to drop yellow pollen all over it that sticks when it rains - ooo and i often have a caterpillar on my car.
hey cam :(
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
yeah i often get in my car to go home and somewhere on the car theres a caterpillar - they must like it :( hehe dont mind caterpillars there cute usually still not on my car by the time i get home tho - blown off in transit hehe :P
nah zenah likes to sleep on the roof :) and its undercover so cant be hot - must be the fact she likes to piss me off haha. Yeah shes a very big n healthy female - vet always comments on how healthy she is.
Cool - just so i know what im kinda doing haha :D
mine was pretty fu(ked to say the least
woke up friday morning knee gave way as i was getting changed, havent been able to straighten my knee since so will have to go back to the orthopedic surgeon soon to get it looked at....
what makes thing even more annoying is that i only just had an op on my left knee now my right knee is fu(ked
hey paul, troy, niz and al...
troy - yea, need that suspension changed if i want to get into drifting.. but the current setup is still good enough to have alot of fun on the way back from toodyay! :D
paul - no drams with the close following - it's all part of the fun.. just don't touch me.. :)
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
