  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Ohh Ok then... I will be an honourary Raven Racer then :D
After your post saying Black Bird I thought you were implying it was for Girls who drive black cars.... :P
My mistake.... If you will still take me I would be honoured to accept :D
Ohhh Black and Evil.. I like it :P
Sorry Paul.... there is just something wrong about being a "Spanker" :D
Ohhh enjoy your games... I play alot of multiplayer LAN games but they are more the CS mod Day of Defeat and some others that arent as popular :D
I play DOD as well. i also play C&C Generals
i play abit of everything
Psiker
