  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
I find the problem with dragon ball z is that because I didn't watch it from the start it doesnt make alot of sense... I understand the concepts behind it, but if you don't know the history of the characters and how they are linked together its bloody confusing.... like when I was in melbourne I watched and episode in the morning where two characters joined into one permanately by joining ear rings.... and if I watched it the day after I would have just thought who is this guy?? And why is he having so many problems with himself :)
Yeh its getting taht way buts its always fun too.
I actually used to go to an anime fan club called JAFWA (japanese animation fan club of WA)on sat nites at curtin. Had to give it up cause the clientelle drove me insane, well almost as much as the shows did. Regardless they have all the best stuff first, some real harcore fans there.
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
