  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Paul,
you need a woman. A full-time woman. then you can resist the temptation to live vicariously through everyone else!
Aidwin,
not really sure. at the moment I think the material may be toooo thin, cause it gets REALLY ****ing hot!
may have to rip it out and use it as a template to rebuild a better thicker one.
In the mean time, it looks ****ing tough!
I guess if anything, it has highlighted to me the importance of having one. It gets so hot it's almost too hot to touch!
Hahaha Zanda,
This is a male friend, and before u ask "I am straight". Me and my ex-gf were very good friends with this guy and his gf. He is here for a weeks holiday. His gf didn't come this time.
He is resting at the moment, but probably go to the city later. He wants to buy another surfboard. He misses Perth. He like the lifestyle here so I guess we will just do stuff he can't in Japan, i.e. surf, tennis, cafe, watch Eagles in the weekend
