  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
i topped 140 in jarrahdale but i wasnt constantly doing that - i would go for a play wait for liz to ctach up the speed off again - it was good that we were both enjoying ourselves at our own pace but still looking out for each other :D although i dont know what i clocked going past that honda that wouldve been more like 160
yeah main thing holding me back was brakes - could see myself plowing thru acorner and hitting a tree. Haha nearly didnt stop in time for that intersection Liz ...... and the time they didnt pull meup with paul yesterday .... he said their worse than his so they must be bad!!
Originally posted by Nizmo
kens lurking ...... come cheer me up ken :D
Babe , I would have given you a hug today but the rest might not understand.
Ex b/f ??
Once there gone , move on girl:(
Cheers
Ken
ken its not - i want to go back its more he's destroying himself and now i feel partly to blame that he's gone so downhill! Ive been living in this "he's ok, hes doing fine - someone suceeded wher ei failed bubble" and its just been popped and i feel head phucked.
Originally posted by G0DF4Th3R
i love Ken's GTR
damn!
only thing it has this disturbing sticker on the rear window
What's wrong with that
kidsheart , girlspanties , dogsbollocks?
who cares , it looks ricey and thats the idea.Hehehe
Cheers
Ken
haha i saw u get out the car Liz and i thought "oh my god shes not going to do what i think shes doing is she?" haha then i thought "go liz!!" same with u asking for the maccas girl to pretend like we bought a happy meal!! that was almost as classy as me stealing a lollipop from a resturaunt haha
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
