  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
There were soooo many sunday drivers on the road today!! it was like phuckheads day out or something! maybe its cos im tired and my patience is lower than normal but one person was doing 60 in an 80 zone!! GRRRRR
Originally posted by dan_the_man
Who got the highest hp today?
Gawd knows cos the 4wd were done at XSpeed and the 2 wheel drives at Genie.
I know Ant ran about 430 at the treads out of his Datto 1600.
Cheers
Ken
Sorry , I did move over...;)
Cheers
Ken
Sides I was trying to get to that Maloo ute but couldn't get the lights right.
( note that gtrken does not condone excessive speed or dragging on public streets )
yea , phucken right:D :uh-huh:
Cheers
Ken
3/4 points ..... not sure ..... think its 4. ;)
nearly got done on the way to the breaky cruise ...... hurtling down abernethy rd 110km ...... motorbike policeman driving along other side ..... u shouldve seen his head turn as this black clur went past ..... *insert a lot of swearing from me* jam on brakes - see him jam on his in my rear vision mirror so i prepare for the worst and get behind slowarse car in lefthand lane ...... but despite me thinking he turned around he didnt - lucky me :)
Originally posted by AeroGrace
anybody see a R32 GT-R in custom purple? Driven by a chick....
did it go on the dyno?
Skyes and its for sale and is near std mechanically so doubt would have run.
Cheers
Ken
yeah saw the ute .... but he was either stuck behind someone or was just grandpa driving ........ i know 2 particular holden clubbie that call my car "jap crap" I would love for u to show whos boss too ;)
Hmmm , then you would have to resort to what we were discussing
1 Low cut top
2 High cut skirt
3 Crying
or 4 is the job that you mentioned:D :)
Cheers
Ken
Or like drews mate who whispered in Liz's ear that I should get a Commodore.hehe
Russ's comment re. why buy something slower was good:)
Cheers
Ken
haha i have done all three in front of a cop and it works ..... never had to resort to 4th ;) just play the dumb blonde (comes naturally to me) and they just think your late for something and u normally drive like a grannie. I love it when cops try and find excuses for me tho - that was sooo funny "oh you dont know the speed limit around here do you (despite it only being 2 blocks from my house) and your late for work ..... where do u work ..... oh that sounds cushy"
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
