try R34 metallic blue :/ or WRX rally Blue if ya like.
Nah i just saw it sitting out in the sun on the side of the road at lunch and thought - if it keeps being left out in the weather like this the paint aint going to be worth shit ....... so it just got me thinking - and a project formed in my mind :)
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
well let me know how much it costs :/ but i think going the full spray job would just be mint! anyway see how much funds go over the next 6 months ..... probably best to put that money towards paying off my debt.
if i do decide to do it its not something thats going to happen overnight ..... gotta save - it would be at least 6 months away!! depending on job situation. Maybe should just get the credit card limit up hahaha.
really? that would be nice ...... yeah want an R34 GTR intercooler .... basically i want it to look as much as possible as an R33 can look like the R34 GTR on my wall haha without all the stickers!!
Hey Cambo! :/
    • How much have you lowered?  I had 350Z springs in the rear and was able to pull the camber into factory spec with the factory arms on the rear, obviously the front ran negative camber as it isn't adjustable, but rotating the wheels regularly evened out the wear.
    • Either the installer needs to come back, you need an auto electrician, or you need to learn automotive electricals yourself.   First step Id look at is where that big thing came out of, is there still things unplugged at that location? Maybe they just forgot to put a relay in or something?
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
