  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
LOL - fair enough niz.. :D
Niz - I'd say he pmed you cause you've seemed very down and agitated lately.. just showing that people do care you know.. :D
Heya paul.. yea - me getting fairly excited.. Me also seein Olivia tonight so I'm pretty happy about that too.. :(
yeah an hour of cardio and an hour of weights - but its still not coming off - when i came back from queensland i stopped having lunch - ate the rest of the meals just skipped lunch and the weight fell off me at an incredible rate - so im going to do that :(
a month paul ..... besides if i can drop that much weight after Queensland its gotta be food. I am gettin fitter tho .... i found that hour fairly easy yesterday .... i used to huff n puff after 15mins.
Originally posted by GTS-t VSPEC
Yeah, I still huff and puff a bit, but getting better. Training with Troy today, and Dan on Friday:D
so I guess you lots are getting fitm very good!!!
anyone of you would like to join CITY TO SURF on 31st/AUG????
one month and bit to go... I am sure you guys can handle 12km run :(
what ya think?
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
