  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
LOL - fair enough niz.. :D
Niz - I'd say he pmed you cause you've seemed very down and agitated lately.. just showing that people do care you know.. :D
Heya paul.. yea - me getting fairly excited.. Me also seein Olivia tonight so I'm pretty happy about that too.. :(
yeah an hour of cardio and an hour of weights - but its still not coming off - when i came back from queensland i stopped having lunch - ate the rest of the meals just skipped lunch and the weight fell off me at an incredible rate - so im going to do that :(
a month paul ..... besides if i can drop that much weight after Queensland its gotta be food. I am gettin fitter tho .... i found that hour fairly easy yesterday .... i used to huff n puff after 15mins.
Originally posted by GTS-t VSPEC
Yeah, I still huff and puff a bit, but getting better. Training with Troy today, and Dan on Friday:D
so I guess you lots are getting fitm very good!!!
anyone of you would like to join CITY TO SURF on 31st/AUG????
one month and bit to go... I am sure you guys can handle 12km run :(
what ya think?
    • A few random issues have popped up since my last update. My WMI pressure sensor failed within about 10 minutes of it seeing liquid. It was a 20$ China special, so I'm not surprised. My name brand replacement should arrive today.  My power steering assist also decided to crap out last weekend. The usual, works for about 60 seconds after starting the car then I lose it. I dusted off my old copy of NDS and connected to the HICAS ECU. Code 4 for assist solenoid.... I tested the solenoid and it's fine.  I knew the day where my HICAS ecu would crap out would come, and I welcome it. It was the last HICAS part on the car that is now in the bin. I've ordered an SSR and I will control the power steering solenoid with my Haltech ecu. It will be nice to have proper speed referenced assist again after all these years.
    • Haha I just finished the last season of TPB: Jail last month. I'm happy they're still pumping out episodes.
    • We want to see pictures of the carnage!
    • The picture of the underside of that PCB shows either old flux that wasn't cleaned properly or some other contaminant (I.E Water). I would flush it with ISO and try again.
    • @silviaz Are you skim coating the entire panel (covering the entire panel with filler) before your hitting it with the long block? Or are you selectively applying filler to the repair, trying to fill the low points?  Please don't do that.  Almost certainly. Are you checking the panel for flatness as you go? Or is it more a case of, sand til all the guide coat is gone then check?
