  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
not very well today - i shouldnt be at work :)
just wrote email to Mel telling her how her housemates are pissing me off ...... thinking of just canning the whole saturday night..... do nothing like i did this weekend.
so you can post as much as you like now!!
I drove back to Omni after Morley and waited there for a while and then went home...
all that good driving on the cruise and then i get pulled over within 1 km of my house.. :)
hmm, damn this 180 seconds!
so how is the new desk?
what did you end up doing after the cruise? i was supposed to go to the rise with friends but wasnt really in the mood after getting pulled over.
Originally posted by Nizmo
not talking to you? what tha? haha how shallow do you think i am?
this 180 sec rule sucks balls!
i just thought that cause i was a bit of a wnaker and carried on when i might have got a bit infront of you from the lights that you were a bit off at me.
I saw American Pie 3 yesterday and that was FUNNY! haha saw it on vcd..
you get done or just warned? haha yeah i had radar detector - saw a policeman on bike on way home ..... on Saturday the friggin barsteds drove past my car ..... and their heads nearly swivelled off their shoulders and they turned around and i thought ..... ok here we go with the yellow .... but then disappeared.
new desk is good ..... i cant be seen as much therefore hopefully forgotten about :) new chickkie aint here yet.
yeah that'll be right as soon as i can post they slap the 180 rule on!!
haha nah your good :D .... jsut you wait i'll have my revenge!! haha
Talking about blue 180 with wanker drivers :) *jk* .... on the way to work this morning there was one like Richies ..... L plates on and was heading down Graham Farmer Freeway ..... now if i remember correctly L-plate drivers arent allowed on the freeway with their girlfriends - who about 17 - instructing and he tried to race me ....... i should of let him go in the hope he got picked up by the coppers :D
I got done 100 in a 70 which is $250 and 4 points.. bummer only got 1 left now!
They were going to give a a yellow for illegal mods too but i played ignorant telling them i am from SA and that i had just bought the car after coming back from the gulf.. which is sorta the truth...
I made tandoori chicken for tea last night and i so cant wait for lunch so i can have the left overs.... Mmmmm yummy~~!!
Hey there Cam!!
Gotta make the most of your posts while the time ticks away, just makes them alot longer!!! Noe i just have to anticipate what you might write...
100 in 70 is that much? haha you didnt barter with them Richie .... i got my 110 in an 80 for 1 point ..... Bargin :) haha
i had two bottles of wine for dinner .... from memory that was it :D
I dunno what the rule is in WA for learners on the freeway but in SA they are allowed to go on and do the limit! (110 in SA)
Have your revenge hey?? MWOOHHAAAA!!!
I might be even faster soon, i am getting a dump and front pipe and cat... then a new clutch (mine is caned now after friday night)...
gotta save up for front mount too..... havent even done my tax yet.
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
