  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
back but gotta go away and teach lady .... no roast beef had roast chicken instead - far healthier i guess anyway.
least ive got appetite back - wasnt feeling to crash hot this morning ..... very tired only got about an hours sleep last night.
anyway everyone nejoy their afternoons im off around 2:#0 anyway :)
