sorry looking at other threads - but im done now :)
im having major gym fest on my days off cos i have been lazy lately!! Plus i wont eat as much when im at home.
Sweet so you coming on Sunday?
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Meet at City West at 10 - 10:30 (check events thread not sure) .... maps handed out on the day but we are ending up in john forest nat park for BBQ lunch BYO meat n beer.
depends how i feel after saturday night whether i go or not .... but i went to dardenup cruise and i was trashed .... although i had somebody to drive otherwise i might not of survived haha.
ahh good weather on sunday is a good thing....
i am getting pissed off with my car, if i accelerate hard up to (and mybe over) 120 i can hear a whining noise coming from the rear of my car, i hope that its nothing. i got a feeling it might be the wheel bearings tho...
might treat myself to a couple of pints at little creatures on saturady i think..
not my idea :) Mel's housemates who i dare not argue with cos they get in a huffy...... they wanted to go Metros RnB Superclub first off and i put my foot down about that .... we only went there a couple of weekends ago. Must admit theres good eye candy in Freo tho :)
eeek not good :) ..... my cars such a slug at the moment .... feel lime im driving a commonwhore gonna leave it til i save up a couple of grand then go see Jash and see what miracles he can perform on it. But i must admit its gone thru going thru about 2 -3 tanks ( 3 on a cruise week) of fuel a week .... to one tank of fuel on a cruise week!! Why all of sudden is the fuel economy got good???
DC's? Drum Club??
yeah last time i was there was my 19th Bday but i was too sick to care trying to control a crazy off his face boyfriend ..... so my memories of the place arent that good.
um fuel economy got better not worse.
haha yeah havent been in ages .... check it out again one day.... just have bad memories of the place that'll stick i think. Bit like the Rise dont like going in there too often these days as well.
Y compo?
umm, i did that about 2 years ago now, i only got my arse into gear to get the compo cause i am getting out... and yeah it hurt like hell... got some nice morphine at the hospital though!
i dunno how much i iwll get but i have been told about $5000, that should be nice but i think that my car will miss out, just cause i have got the shits with it and by the time that i will get it the house will need painting and the gardens will need doing...
Such a nice feeling when your boss has gone to Canberra for half ya last week and you know when he comes back you wont be there to be shouted at if things havent been done ...... ahhhh freedom. :)
My cars interior is in desperate need of a clean - i used to keep it spotless but at the moment its really untidy!
$5,000 & Morphine wow .... *niz looks around for airtight doors* ...... Doh! :)
haha i bet you spend it on ya car anyway :)
Guys with cars n houses never spend any money on their house unless its neccessary!
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
