  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Ken, Did the truck get taken away? Did Shaun offer to sell it?
You aren't going to believe it but there was 6 speeds in that crappy box and it's turboed!!
Never felt it kick in but he said it won't boost till 2,300 and he rings it out till 3,500.
We changed at 2400...
Cheers
Ken
The runt might not survive another hammering but if it's still here , then guess what...:(
Originally posted by Nizmo
hehe i wanna be around when the neighbours dog gets a FW up the arse!
Ken thinking of buying slow arse trubblesome truck ........ with two ugly mugs on the side?
Won't be troublesome, we fixed the thing as we went:mad:
He wants too much atm but I told him when he wants to really sell it , talk to me.
Cheers
Ken
the person "interested" going to do the work on her?
i think you should let me have a drive of the Runt before you sell her .... after all i cant do much more damage than whats already been done *insert puppy dog eyes here* :(
Is that opposed to 2 ugly mugs inside ?? hehe
Cheers
Ken
It will cost you.....
Cheers
Ken
LOL @ Ken, Didn't know it was turbo, and I thought you and Lumpy were mechanics:p
Didn't say I was any good..:(
The thing never gave any indication it was and there certainly was no * kick in the back* but as the posts above say ,we changed just as it started to come on:mad:
Cheers
Ken
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
    • The annoying part about neglect, is when you start to replace one thing, and find ten more broken things. Ham fisted monkey repairs you normally only find out about when trying to do something unrelated! Ha ha   Neglect you can kind of anticipate the huge costs to fix it all. Ham fistedness is normally a shock the first time your work on a new old car, as everything "looked" good before.
    • For DBA, check out their guide table here. https://dba.com.au/wp-content/uploads/2023/01/Direct_Replacement-Guide-2021.2.pdf   Additionally they have some other guides and info on how to make sure you choose the right pad.
